Programmatically Read/Write Custom Metadata to System in SystemLink
 Is there a programmatic way to read/write the custom metadata fields in a SystemLink managed system? I've looked at the SystemLink palette but do not see an obvious way to accomplish this.
(2,670 Views)
Accepted by topic author CAC10268
This is far from complete, but I added a simple example on how to read the system metadata using the HTTP API.  You can get more information on the HTTP API if you click on the ? in SystemLink on the top right when you have the Systems Manager application open.
https://github.com/joshuaprewitt/systemlink-labview-http-examples
You would have to use the /v1/systems/managed/{id} route to update the metadata, however doing a PATCH in LV can be a little tricky.
Also parsing the properties dictionary will require some string parsing, because the normal Flatten from JSON doesn't support them.
I'll try to improve the example when I have some more time to work on it.
(2,633 Views)
Have you made any updates to this?
(2,183 Views)
