Showing results forĀ
Search instead forĀ
Did you mean:Ā
Convert GMT Time to Local time
Someone can help me..
I am reading the data from a GPS and its send me the GMT time, how I can convert this GMT time in Local Time using Labview7.0
Thank
(5,780 Views)
In LabVIEW 7.0 you might have some problems, but recent versions have a clear distinction of timezones. What code do you have allready?
Take a look at the time formatter strings available for 7.0 (I don't know which you have).
Ton
My LabVIEW Ideas
(5,772 Views)
In what format are you getting the time? As a string? Are you converting it to a timestamp? If so, you just need to add/subtract your time zone difference, in hours.
EDIT: Just saw the note on LV 7. I did not test the above in 7.0 as I don't have 7.0.
Message Edited by smercurio_fc on 01-07-2009 12:16 PM
(5,771 Views)
There's a post on LAVA with a VI to return your current time zone.  Add this to GMT from the GPS and Bob'll be your uncle.
Jim
Jim
(5,769 Views)
There's got to be a better way than this:
Message Edited by jcarmody on 01-07-2009 12:53 PM
Jim
(5,756 Views)
Is this best?
Message Edited by jcarmody on 01-07-2009 01:13 PM
Jim
(5,737 Views)
jcarmody wrote:
Is this best?
Probably. Except that I don't think %z is available for LabVIEW 7. In the LabVIEW 7.1 manual it mentions %Z, but not %z.
(5,728 Views)
