Convert Labview 2002 VI to Labview 2020
I need to convert or Run a VI developed in 2002 Version on Labview 2020.
Is there anyway i can get a conversion Kit or which all parts i need to focus while converting?
(3,096 Views)
Accepted by Jen_Joy
Option 1: Use the Version Conversion board.
(3,078 Views)
What version is "LabVIEW 2002"?  Back then, the year was not part of the version number.  I estimate it would have been about LabVIEW 6.
This chart will help to tell what you need.
https://www.ni.com/en-us/support/documentation/supplemental/09/how-to-upgrade-or-revert-a-vi-to-a-di...
If it happens to be LV 5.1, then you need to open it and save it in a version between 6.0 and 8.2.  Then you can then open that one in versions newer than 8.2
(3,058 Views)
Hi Jen,
there is no "2002 Version": the years in the LabVIEW version number started with LV2009…
(3,054 Views)
Hi GerdW,
Thanks for the reply.
Sorry i made a typo. Its 2012 , not 2002.
While i open 2012 VI on a 2019 version, it is showing errors in calling libraries.
(3,033 Views)
2020 will open 2012 just fine.
If you are getting errors because of missing libraries, that means you don't have something installed.  What do the error messages say?  What libraries?
Perhaps they are instrument drivers you need to download.
(3,028 Views)
