Convert Labview 5.0 to Labview 8.5
Attached are in 8.2, which you should be able to open. You should read over the warnings that the mass compile generated.
Message 101 of 152
(2,107 Views)
hello,
Does anyone can help to convert attached files from LV 5 to LV 8.5 ?
Thanks a lot!
Yawen
Message 102 of 152
(2,048 Views)
I am going to use the racal instrument, 1260-00C and 3152a. The instrument driver's version is too old to convert latest version(2009).
So, please help me in converting the existing LabVIEW 5.1 code into latest version(8.0 later).
Attached the LabVIEW Libraries to be converted.
Message 103 of 152
(2,043 Views)
Hi Yawen,
Here you go, I have convert them to 6.1, you can open them with 8.5.
Message 104 of 152
(2,033 Views)
Hi bbias,
I dont exactly know what your attached are, they are not VI code.
Message 105 of 152
(2,031 Views)
Thx, aris.
The attached files are zipped files. So I unzipped those files.
And Those are instrument driver files which are fomated as old version, lv 5.1.
So, please convert those files into the later version (lv 8.0 or later)..
Message 106 of 152
(2,022 Views)
Hi bbias,
Here they are, I have converted them to LV2009.
Message 107 of 152
(2,017 Views)
Dear all,
I would like to use Keithley-Driver for my KPCI-3102 Card. At the Keithley-site I found a driver. Unfortunatly it is not compatible with my LabView 2009.
Can anyone help me with this problem, or has a good idea to solve the problem?
Thanks in advance
 Nils
Message 108 of 152
(1,956 Views)
it is me again. I found some llbs in the "user.lib" directory. Probably it is enough to convert them, am I correct?
I zipped the files and attached them.
Cheers,
Nils
Message 109 of 152
(1,945 Views)
nils1982ks wrote:
Dear all,
Thanks in advance
 Nils
I think this may have already been done here.
Message 110 of 152
(1,936 Views)
