Convert Labview 5 VI into Labview 8.6
R U kidding? O my god, you are so efficient. Thank you very very much! you solved the prolem bothering me days.
Message 11 of 46
(3,354 Views)
O, a little problem, the Orbit_if.DLL's subvi OrbitNotify still cann't openned by Labview 8.5.  It almost makes me  crazy.
Message 12 of 46
(3,343 Views)
problem solved, thank you Ray.
Message 13 of 46
(3,340 Views)
Glad it worked.
I would not have been able to do much about a dll without the complete source code (and corresponding compiler 😉 )
Message 14 of 46
(3,323 Views)
I was finally able to get the other file, here are all of them again:
Message 15 of 46
(3,292 Views)
are you the same person as pacino21?
Message 16 of 46
(3,285 Views)
No I am not.  You said you would be able to convert the rest of my files if I found the Read Peaks file.
Will you be able to do it?
Message 17 of 46
(3,275 Views)
Oops...  I just now realized that there were two different people who posted files in this thread..
Sorry about that.  Yes.  I should be able to do it later today.
Message 18 of 46
(3,272 Views)
Hi Ray,
Here is a part of a program from my friend (quite simple), the problem is that there is no Timing VI in both output process and input process (data acquisition process). In this condition, can I know the  data acquisition period, or the rate at which data points (samples) are being acquired (sampled).
Thank you very much!
Regards
Message 19 of 46
(3,253 Views)
Hi Pacino21,
Please start a new thread with this question, in case I could not help you and so that others get visibility for your need.  The other reason is that it gets confusing within this thread as I might convert it to another version by mistake  😉  LOL!!  😄
Hi Chris,
I'm converting what you provided.  There are still some missing subvi's related to the HP70200, such as:
HP70200 set markers.vi.
and
HP70200 read markers.vi
Please check what other subvi's I should convert and post them all (zipped is acceptable).  It does look like your only missing those two.
Cheers,
RayR
Message Edited by Ray.R on 11-18-2009 03:49 PM
Message 20 of 46
(3,239 Views)
