Convert Labview instrument driver from 6.1 to 6.0.2
Could someone help to convert the following LV6.1 driver to 6.0.2?
 http://www.eu.anritsu.com/files/MT8820A_MainFrame_LabView_Driver_v332.zip
http://www.eu.anritsu.com/files/MT8820A_GSM_LabView_Driver_v340.zip
Thank you very much,
Ryan
(3,294 Views)
Try this.  Had to break one into 2 zip files due to NI forum limit on attachment size.
(3,287 Views)
Yes it works! Thank you very much!!
Ryan
(3,232 Views)
Sorry Matthew,
Could you help the conversion of the following file as well?
http://www.eu.anritsu.com/files/MT8820A_W-CDMA_LabView_Driver_v340.zip
Ryan
(3,174 Views)
Here you go.  It's possible that you may have trouble unzipping, as I had to use higher compression levels to get it to NI's size limits.  Let me know if you have problems.
(3,162 Views)
Hi Matthew,
Unfortunately, it does not work.
Any chances sending it through?
Ryan
(3,131 Views)
I had to break up the LLB to be able to get ZIP files to fit under NI size limits.  You will need to rebuild the LLB file if you wish to keep it as an LLB.
(3,116 Views)
