Convert .NET color reference to LabVIEW color
Hi all,
I am trying to convert a .NET FontDialog/Color reference to a LabVIEW color.  I'd like to somehow get the RGB values from the reference then use the "RGB to Color.vi" but can't find an appropriate Property/Method from the reference.  Please help.
Thank you,
Message 1 of 9
(5,229 Views)
You can call the To ARGB method to get the RGB value. It looks like an I32, so you might need some byte reshuffling to get it to the correct LV format. Split Number and Join Number should help.
If that doesn't help, post some actual code of what you've done and what you expect.
___________________
Try to take over the world!
Message 2 of 9
(5,202 Views)
Accepted by sangbui_palpro
Hi tst,
Thanks for your help.  I got it to work by using the ToArgb method.  I attached a picture of the code.  The following link from Microsoft is also helpful.
http://msdn.microsoft.com/en-us/library/system.drawing.color.toargb.aspx?cs-save-lang=1&cs-lang=cpp#...
Palpro
Message 3 of 9
(5,178 Views)
The ToARGB should be the same form a LV-color, so the byte splitting shouldn't be necessary. Try it, just connect the ToARGB directly to the color box. 🙂
The 1st byte includes the Alpha value which should be ignored by LV, if it isn't you can mask that information away by 0x00FFFFFF AND color.
/Y
Qestit Systems
Certified-LabVIEW-Developer
Message 4 of 9
(5,144 Views)
Hi Yamaeda,
I tried it.  It didn't work.
Palpro,
Message 5 of 9
(5,129 Views)
Works well. 🙂
/Y
Qestit Systems
Message 6 of 9
(5,122 Views)
Yes, it worked.  Thanks.
Message 7 of 9
(5,117 Views)
How do I convert the vice versa of this?  I have labview color control and want to get the respective .net color reference.
Ajay MV
Message 8 of 9
(4,833 Views)
Generally, these things are not hiding and make some sense. The Color class has a ToArgb method, so it shouldn't surprise you to learn that it also has a FromArgb method, which presumably does the opposite.
___________________
Message 9 of 9
(4,808 Views)
