Convert String to Decimal for Zigbee on NCD board
Thank you for your response. I am having trouble understanding what is posted however. I am finally able to get an output from the R Visa, but it only returns "U". So I was wondering what is within the case structure labeled "12 bit"? It seems like a lot is going on there, but I would like to be able to see what the outputs are in Dec or number format.
Thank you.
Message 11 of 15
(633 Views)
Yes, and the ascii code for an upper-case U in decimal is (drum roll please): 85!
Mike...
Certified LabVIEW Architect
LabVIEW Champion
Message 12 of 15
(630 Views)
Capital U is an 85 (you really should keep an ASCII Table near by at all times).  Did you change the string to a byte array?  From there, Jeff was combining bytes to get larger data types based on the manufacturer's command structure for a 12bit acquisition.
Message 13 of 15
(629 Views)
Thank you Everyone!!!
Message 14 of 15
(621 Views)
Mike...
Not bad for coding from spec!Smiley Very Happy
Message 15 of 15
(617 Views)
