Convert Traditional DAQ to DAQmx - DIO Port Configure
I am switching all of our DAQ software from Traditional DAQ (Legacy) to DAQmx, and I'm puzzled by one vi - the DIO Port Configure vi.  I've attached a jpg of my traditional DAQ code.  Can anyone show me how to convert this to DAQmx?
Steve
(4,501 Views)
You can use the DAQ Assistant to generate some general code for this. It would look something like this.
Tim
GHSP
(4,469 Views)
That works great!  Thank you.
Steve
(4,458 Views)
Hi Steve,
I would also recommend taking a look at our DAQmx examples.  These examples can be found by using the example finder in LabVIEW (Help » Find Examples).   Our  DAQmx digital I/O examples can be found by going to  Hardware Input and Output » DAQmx » Digital Measurement, Digital Handshaking, or Digital Generation.  You could also compare these to the Traditional DAQ examples found under » Hardware Input and Output » Traditional DAQ.
I hope this helps,
Paul C.
(4,443 Views)
All,
A bit late but there is a wizard to assist in the upgrade process.
Matthew Fitzsimons
Certified LabVIEW Architect
LabVIEW 6.1 ... 2013, LVOOP, GOOP, TestStand, DAQ, and Vison
(4,431 Views)
Thank you also, Paul and Matthew.  That information will all be helpful as I convert my software.
Steve
(4,425 Views)
