Convert a 2D table of strings to table of 2 clusters
I need to convert from a 2D table of Strings to a Table of 2 clusters
In the VI .. i must convert Table 1 to Table 2
Please help me
Thanks and best regards
~~~~~~~~~~~~~~~~~~Looking for a LABVIEW JOB (In EUROPE)>~~~~~~~~~~~~~~~~~~
**The Best Way To Predict**The**Future Is To Invent It**
Salimos - View my most interesting photos on Flickriver
(3,268 Views)
I'm pretty sure a table can only be a 2d array of strings.  You cannot put clusters in a table.
edit - OK, after looking at your VI some more, you're not using tables.  You want to convert a 2d numeric array to a 1d array of clusters, which you can do like the following
Message Edited by JeffOverton on 06-05-2008 10:08 AM
(3,266 Views)
Thank you for ur precious help, Smiley Happy
yes indeed im trying to convert a 2D array of strings to an array of 2 clusters,
can you explain to me what you have insert in the For LOOP?
(3,253 Views)
Hi salim_mjs,
you can also use the "array to cluster" function. right click on this function and select your size (in your case 2).
Mike
Message Edited by MikeS81 on 06-05-2008 04:36 PM
(3,248 Views)
Hello Mike,
I tried your method.. but it isnt working for me.. cause i want as an output a array of 2 clusters
and the error is that in the output of the loop i have a cluster of 9 Elements, but in need just 2.. :S
Can you help me to solve this?
thanks in advance,
(3,244 Views)
Hi salim_mjs,
as i said, right click on the Array to Cluster element and select "Cluster size". Change this value from 9 to 2. Smiley Wink
Mike
(3,240 Views)
Hi Mike,
Finaly its working 🙂
Gracias, Merci, Thank you , Shukran Smiley Happy
(3,236 Views)
