Run Labview as different windows user (for database connectivity)
I have to connect to a corporate remote MSSQL-Database on the network, using the database connectivity toolkit for LabVIEW.
The db-authentification is realized checking the windows user (ads) who acceses the datebase (not a database user / password which is standard in the database vis)
Therefore I have to run LabVIEW as the defined windows user, different than the logged in user on the pc.
Is that possible to realize with LabVIEW?
Other Windows-tools allow to define the windows user/password which "run" an application - how can I do that with LabVIEW?
(2,809 Views)
Hi Zav.  There is a windows command 'runas' which _may_ let you do what you want; I haven't
tried what you need to do, but is has worked for other tasks for us.  Try 'runas /?' for the switches.
You will have to build your LV program into an executable, then use runas to launch it.  Is there
a reason you can't just login to Windows as the required user?
If you can get your db admin to allow dbuser/password authentication that would be a much better
way to go.
Matt
(2,793 Views)
Thanks for the hint - I every day can learn new things.
For me it seems to works with
runas /netonly  ...
even I start the LV developement enviroment.
(2,781 Views)
runas /netonly  ...
Thank you, Zav, now I get to learn something too!
Matt
(2,769 Views)
