Convert a Single Number to a 32-bit hex string and swap the high and low bytes
I need to convert a Single Precision Floating Decimal number to 32-bit hexadecimal form, swap the high and low bytes, and convert that to a hex string.  I have tried using the "Swap Word" function but it doesn't seem to have any affect on the Single number.
So
Input a Single Decimal # : 100
Convert to 32 bit Hexadecimal String with the low byte first: 0000 42C8
 Any one have any ideas?
Message 1 of 11
(12,162 Views)
Use "flatten to string" and set the byte order to little endian.
Message 2 of 11
(12,159 Views)
awesome! thanks
Message 3 of 11
(12,149 Views)
Actually, the above answer is incorrect if you really want the 100 -> 0000 42C8 functionality. You seem to want an unusual conversion.
Try this instead:
(left to right: typecast to U16 array, reverse array, typecast to string)
Message 4 of 11
(12,146 Views)
Sorry spoke too soon...
That using flatten string with little endian gives me "0000 C842" instead of "0000 42C8"
Message 5 of 11
(12,145 Views)
Yeah that's what i'm looking for.  I am using Modbus RTU to control a motor controller and it calls for its data in that format.
Message 6 of 11
(12,130 Views)
Accepted by drb12345
Slighly more lightweight, try casting to U32 and swap the words. Same difference. 😉
(apparently, swap words is a NOOP for SGL, but still accepts SGL without coercion dot. Interesting...)
Message 7 of 11
(12,127 Views)
You should unmark message 2 and instead mark message 4 or 7 as solution. Thanks!
Message 8 of 11
(12,117 Views)
I have the feeling that the current behavior of swap words is incorrect for SGL inputs. I created an note in the monthly bug thread. Any comments are welcome.
Message 9 of 11
(12,093 Views)
My guess is that this is somewhat intended behavior.  You are able to wire a cluster with multiple data types and it will swap bytes/words on integers and leave the others alone.  Not that I have ever thought about doing this....
still seems a bit strange.
Detailed Help: data is an integer, an array of integers, or a cluster containing integers that you want to byte swap. If data is a cluster that contains integers, this function swaps only the integer elements of the cluster.
Message 10 of 11
(12,083 Views)
