Convert byte array to float
I have a byte array which I get from the sensor. I have manage to seperate the payload into three 4 sections. A and B and C are float values: A=+43.57, B=+1.88, C=-2.02. How may I proceed? I have tried type casting and converting to big endian. It doesnt work. Any ideas?
(14,122 Views)
You are searching for FA but the attached VI with default doesnt contain FA.
Share us the data payload which you got and the expected decimal Value. will help you in converting using LabVIEW.
Palanivel Thiruvenkadam | பழனிவேல் திருவெங்கடம்
LabVIEW™ Champion |Certified LabVIEW™ Architect |Certified TestStand Developer
Kidlin's Law -If you can write the problem down clearly then the matter is half solved.
(14,113 Views)
In my project everything is correct. I duplicated the file and have mistakenly typed AA in the field. It should be FA.
(14,111 Views)
I hope i i did similiar conversion couple of years before, i rememeber i gave the reference for typecast is SGL instead of DBL.
Just have  a try.
(14,103 Views)
 Its Working Just try this
(14,095 Views)
Accepted by topic author aan928
Hi aan,
each part, consisting of 4 bytes, should be typecasted to a SGL value.
- Right now you typecast to DBL - FAIL 😄
- When the byte order is wrong you should use Reverse1DArray on those 4 byte-parts. Using SwapBytes/Words is wrong too…
- You can also use UnflattenFromString, which gives you the option to change the byte order for free…
(14,092 Views)
