How to Programmatically swap the Y-Scales of a waveform chart and how to build the fly through legend?
I'm trying to customize the waveform chart, Need following Features:
1. I want to add and also swap multiple scales (say 6) programatically. Also I want to swap the Y-Scales during runtime.
2. Want to create a fly through legend. (To move the legend in runtime).
3. Need to access the "Plot visibility checkbox" programatically. (To select/Unselect the particular plots)
Please let me if there are any solutions.
Thank you.
Siva
(3,770 Views)
Hi ramssrk,
1. You need to create the scales at edit time and make them (un)visible as needed. (Charts only allow one X axis with several Y axis, while graphs allow multiple X and Y axis…)
2. Don't know anything like a "fly through legend". Can you explain this?
3. Each plot has properties. You can read and write these properties!
(3,758 Views)
Hi GredW,
Thanks for the quick response.
1. Yes I can add and swap the Scales during edit time, but is there any way to do these during run time?
2. I mean to say that during runtime i want to move the legend.
3. I checked the properties but i didn't find a solution to programatically select/unselect particular plots.
Would you please help.
Siva
(3,750 Views)
Hi ramssrk,
1. No, not at runtime…
2. There's a position property of the legend…
3. There is ActivePlot and Plot.Visibility…
(3,748 Views)
Thank you so much GerdW
(3,731 Views)
