Convert float to string?
When I am converting a float to string it drops the leading zero even though I have it specifically set to keep them.   In the end, I need to spit out the form CMDxxx.x and CMDxx.xx.
(9,386 Views)
Accepted by dt1804
What you really want to use is the Format Into String function. Example:
Also:
  • Eliminate your local variables: they serve no purpose.
  • Learn to use the wiring clean up tool. Smiley Wink
Message Edited by smercurio_fc on 03-23-2009 03:48 PM
(9,378 Views)
... and value property nodes. They are even worse!
Simply wire from the control terminals (voltage, time) to the case edge and then to wherever the value is needed.
(9,364 Views)
Thanks all for the help and advice.
(9,357 Views)
