Convert string to number
Hi
Have a vi controlling a Keithley 236. It returns a string as a measurement value. I need to do some arithmetic on this and other values. I Can't do this when its a string but when I convert to a number I get a duff conversion.
Any ideas?
Message 1 of 9
(4,939 Views)
I don't know the definition of "duff conversion" ;). How do you convert?
Please show is how the string looks like and what you want as a result (DBL, U16, etc..).
Message 2 of 9
(4,924 Views)
What does the string look like? Is it a floating point number, like 1.23, or an exponential, like 10.4e3? If so, use the Fract/Exp String to Number conversion found in the strings palette. If the string contains other characters, you must take a subset of just the numerical expression. If the string is a hex representation of bytes, use the Type Cast function found in Advanced - Data Manipulation.
- tbob
Inventor of the WORM Global
Message 3 of 9
(4,921 Views)
Besides the other comments, there's a driver available for this instrument that already has all of the string to number conversions. You can download it here. It's a pretty old driver (matches the age of the instrument, I guess) but it would provide a good starting point if you feel that you need to create your own.
Message 4 of 9
(4,914 Views)
Thanks a lot guys, I'm going to try all this stuff this morning!
Cheers
Message 5 of 9
(4,891 Views)
But what is a "duff"?
P.M.
Putnam
Certified LabVIEW Developer
LabVIEW Champion
Message 6 of 9
(4,885 Views)
A "duff" conversion is a conversion which doesn't work.
A "duff" beer (in this sense, not in Springfield ;)) is a really bad beer.
A "duff" anything is a general expression of negativity over the current state of being.
As far as I know.
Hope this helps
Shane.
Using LV 6.1 and 8.2.1 on W2k (SP4) and WXP (SP2)
Message 7 of 9
(4,877 Views)
Yikes..
I've been "DUFFed"!!
Thanks Shane for explanation (and examples).
Message 8 of 9
(4,874 Views)
Hello David,
maybe you have to change the initialization of your Keithley 236. They have some output options (with or without unit/status/etc). Use the output options with just the number, then the conversion should be no problem...
Message 9 of 9
(4,865 Views)
