Convert string to timestamp
Ohhhhhhh. Well that makes sense now.
Cheers
Message 21 of 24
(2,764 Views)
Hey all,
I just stumbled across this old post because I'm going through a similar problem.  I'm trying to read a .txt file with dates in a %m/%d/%Y format.  I would like to convert my string into date time datatype so that I can do some calculations on it.
Looking at the Format Date/Time String function, it looks like the input is date time, and output is string.  Is there any way to flip it backwards so my input is the string and it outputs date time?
Thanks.  Very new to using LabView.
Message 22 of 24
(1,808 Views)
you mean like this?
Former Certified LabVIEW Developer (CLD)
Currently using LabVIEW 2022
Message 23 of 24
(1,794 Views)
This was the solution that worked best. It uses all of the elements, day, month, and year. Great work.
Message 24 of 24
(237 Views)
