09-04-2015 11:51 AM
Ohhhhhhh. Well that makes sense now.
Cheers
--------, Unofficial Forum Rules and Guidelines ,--------
'--- >The shortest distance between two nodes is a straight wire> ---'
04-14-2020 04:28 PM - edited 04-14-2020 04:29 PM
Hey all,
I just stumbled across this old post because I'm going through a similar problem. I'm trying to read a .txt file with dates in a %m/%d/%Y format. I would like to convert my string into date time datatype so that I can do some calculations on it.
Looking at the Format Date/Time String function, it looks like the input is date time, and output is string. Is there any way to flip it backwards so my input is the string and it outputs date time?
Thanks. Very new to using LabView.
04-14-2020 06:18 PM
you mean like this?
08-06-2026 02:17 PM
This was the solution that worked best. It uses all of the elements, day, month, and year. Great work.
