Convert variant to Integer I16
Hallo,
i am unexperienced LabVIEW's user and I want to convert variant data into I16. For this purpose, I use variant to Data function form LabVIEW Block diagram. I can't define a constant/control I16 to connect to the specified port.
Do anyone has a clue on how to actually do this?
thanks for your help
Message 1 of 10
(5,053 Views)
Drop a numeric constant (it's the blue one) on your block diagram.
It will default to a I32.
Right Click on it and change it to I16
Omar
Message 2 of 10
(5,043 Views)
after creating the numeric constant you need to select its representation from a Right-Click
Message 3 of 10
(5,042 Views)
Hi Aristocate,
you put a numeric constant on your BD, right-click it and change it's representation to I16…
This is pretty basic LabVIEW programming so you should take the time to go through all those free beginner resources offered by NI!
Message 4 of 10
(5,037 Views)
hi all,
Thanks for your help!
I would like to take the CLDA certificate. Do you have some recommendation to make concerning self-learning material and free online test?
Message 5 of 10
(4,999 Views)
Hi Aristocrate,
see those links:
https://learn.ni.com/learn/article/labview-tutorial
http://www.ni.com/academic/labview_training
https://www.ni.com/docs/en-US/bundle/labview/page/block-diagram-data-flow.html
https://www.ni.com/docs/en-US/bundle/labview/page/using-local-and-global-variables-carefully.html
https://www.ni.com/en/support/documentation/supplemental/06/learn-10-functions-in-ni-daqmx-and-handl...
https://download.ni.com/pub/devzone/tut/floating_point_in_labview.pdf
When you have a current SSP contract with NI you are entitled to online training, check this too. Your local NI representative will advise you too…
Message 6 of 10
(4,994 Views)
@Aristocrate wrote:
hi all,
Well its a CLAD if we are talking about the same certification.  Look over on the Certification forum under the special interest boards for some worthwhile advice.
Message 7 of 10
(4,979 Views)
@JÞB wrote:
@Aristocrate wrote:
hi all,
Don't be harsh on him for spelling until you know the full story Jeff - he could turn out to be as good as Ben in 20+years!Smiley Wink
CLD; LabVIEW since 8.0, Currently have LabVIEW 2015 SP1, 2018SP1 & 2020 installed
Message 8 of 10
(4,970 Views)
@James_W wrote:
@JÞB wrote:
@Aristocrate wrote:
hi all,
My bad.Smiley LOL  Lord knows my typing has been known to contain the occasional error!
Message 9 of 10
(4,965 Views)
That's real funny! I hope you make much fun as you code :), Smiley HappyI meant CLAD. thanks again for the link it's been helpfull.Smiley Wink
Message 10 of 10
(4,933 Views)
