Convert waveform (DBL) to a cluster of 2 elements
Can someone help me convert waveform data type (DBL) to a cluster of 2 elements (X,Y). I found a few examples online but I keep getting an error when I wire everything together. I'm using Tektronix's VI's to acquire a signal from channel 2 of my oscope, which I'm able to get but now I want to convert this data to a cluster so I can use it for an existing acqusition application. I've attached my VI version 8.2.
1Thanks
(3,818 Views)
Accepted by lowski
The Y is easy since that is part of the waveform data type.  The X you will need to compute based on the dt using a FOR loop.
(3,806 Views)
Thank you for the help! That was my issue I was able to get the Y component but I couldn't figure out how to get the X component.
Thanks for the clarification.
-Lowski
(3,792 Views)
