Converted exe file from trail version whether works after 30 days
i have created program using NI labview trail version software and the hardware i am using is NI Compact RIO hardware. I have build and created EXE file into the Compact RIO hardware Now its working fine whether after 30-days trail version is over whether it works without any problem because the software i am using is a trail version
(2,821 Views)
Wow.
Is this the usual case?
Do applications built with a 30d-trial have no "expiration"?
Guenter
(2,813 Views)
The built application should still work since it's relying on the LabVIEW Run-Time, not the development environment, and the Run-Time is a free download. However, the built executable should still show the "evaluation version" watermark right on the front panel. Not something I would show to prospective customers.
(2,801 Views)
Right you are.
Nevertheless, it is another justification to encourage people starting with the 30d-trial.
(2,799 Views)
