Converting Modbus integer to float
I'm working on a VI that controls an electric motor through an Emotron AC drive, using the modbus library. I have no problem getting the motor to run and read its speed, however when trying to read the torque i get a problem.
It seems the Emotron drive is using its own format for floating point numbers, see attached page from the manual. So when reading the torque in Labview i get a number like 65431 something, how can I convert this to floating point using the method descriped in the manual?
(6,678 Views)
Hi Sur,
like this:
(I hope I did the bit counting correctly…)
(6,675 Views)
Accepted by SurKaktus
Too late to edit my previous post…
Forgot to take into account the sign expansion of the exponent:
(6,661 Views)
Thank you very much! Worked perfectly.
(6,640 Views)
