Converting an array of XYZ values to an RGB image
Hello!
I have a 2D array of XYZ values.  I want to create a 2D image where the color of a pixel is a mapped value from the Z coordinate (a contour plot).  Right now, I just have the Base Labview version, so I don't have any of the contour plot VI's.  I do, however, have the intensity plot, but it's usually pretty blocky.  The values I'm working with are as follows:
X: 0 to 20
Y: 0 to 100
Z: 0 to 1
Is it possible to either:
  • Map out an image using the array to make a set of pixels to, then, create a bitmap?
  • Space out the data better so the intensity graph isn't so blocky?
  • Something else to create a 2D Contour plot from a list of XYZ coordinates?
Joe
(5,373 Views)
Hi Joe,
Yes.
Yes.
Yes.
All your questions answered…
Spoiler
- you can interpolate your pixels to a finer resolution
- you can read the image of the intensity graph using it's property or method nodes
- you could try to draw your "2d contour plot" using a 2DPictureIndicator and all those draing functions
- there are toolkits found in VIPM, that allow for fine looking graph indicators!
(5,343 Views)
Ha!  Thanks GerdW!
To clarify, my input array looks like this:
[ X, Y, Z
x1, y1, z1
x2, y2, z2,
xn, yn, zn]
(n rows, 3 columns).  I want the X and Y values to correspond to pixels, and the Z values to signify a color at the (X, Y) point.
I'll work with the intensity graph a bit more, but I'm not sure if you understood what my input data was.
Joe
(5,305 Views)
Accepted by topic author JoeKellyATI
Hi Joe,
X: 0 to 20
Y: 0 to 100
Z: 0 to 1
- Initialize a 2D array of 21 columns (X=0…20) and 101 rows (Y=0…100).
- Autoindex your data array row by row: use the XY coordinates to put the Z value into your 2D array using ArraySubset
- wire the resulting 2D array to an intensity graph…
(5,297 Views)
