Physical channel setup while VI running.
Silly question. When I choose physical channels before I start VI works fine. Once I started VI and try set up channels program doesn't read them.
How can I sort it out.
It is not comfortable as I built exe file to stop running program to set channels.
gregorian7
(2,814 Views)
Accepted by topic author gregorian7
Hi gregorian,
THINK DATAFLOW!
Read the physical channel input only when you want to create the task - and not (much) earlier…
(2,810 Views)
