Converting csv files to signals
for some reason it won't let me upload it with the .csv extension so just change the extension after you download it
Message 21 of 31
(2,085 Views)
Your Read From Spreadsheet has the wrong delimiter for a csv file and of course reading as an integer is absolutely incorrect. Troubleshooting your problem was simple. You could have simply created an array indicator on the output or used a graph to show the waveform being read.
Message 22 of 31
(2,074 Views)
Ok.  Then which delimiter do I need for a csv file?  What do I need to read it as?
Message 23 of 31
(2,067 Views)
A comma.
Right now you have no delimiter wired, which means it will use the default value of a tab.
Message 24 of 31
(2,065 Views)
Alright then what?
Message 25 of 31
(2,059 Views)
Then run it.
Message 26 of 31
(2,053 Views)
The same error is appearing
Message 27 of 31
(2,051 Views)
Which error is that?
Post the latest version of your VI.
Have you remembered to account for the fact that you .csv file appears to have some rows that look like header information and not data?
Message 28 of 31
(2,043 Views)
It's the first error I mentioned: error 200077.
Message 29 of 31
(2,040 Views)
Then what I said about the header rows applies.  The first several lines of your attached .csv file are messy and include text in there as well as numbers.  They aren't going to convert well to a number and will turn out to be zero.
Try putting some indicators on your 2-D double arrays coming out of the Read Spreadsheeet functions.  See if that data actually looks like what you think it should be.
Message 30 of 31
(2,034 Views)
