Converting from LabView 4.0 to 8.5
hi there, i have files here. could someone please convert it to 8.5. you help is greatly appreciated. :robothappy:
Message 61 of 81
(1,819 Views)
Can't do it completely. There are VIs being asked for from an IMPGRNL.llb library. Even if they get upgraded you wouldn't be able to use them because of the missing VIs. The Example.llb also seems to be looking for numerous VIs from some other place.
Message 62 of 81
(1,811 Views)
hi, sorry about that. i have attached all the files in a rar folder. it should have all the required VIs. thanks
Message 63 of 81
(1,806 Views)
Hi knight12,
I made a mass-compile with LV7.1, that should be enough... A warning: a dll is still missing.
(For easier working a copied all files into one directory "disk3".)
Message Edited by GerdW on 01-15-2010 04:41 PM
Message 64 of 81
(1,802 Views)
Is it possible run a Vi from labview 9.0 at labview 6.1?
Message 65 of 81
(1,763 Views)
No. It's not possible to run a VI from any newer version in any earlier version. See this.
Message 66 of 81
(1,760 Views)
Hi Gerbm
yes - after converting from 9.0 (to 8.6 when event structure is used) to 8.0 to 7.1 to 7.0 to 6.1. In that order. All the steps.
(And of course without using any new features of LV7.0-9.0 in that vi...)
Message 67 of 81
(1,756 Views)
Thanks for the tips!
Message 68 of 81
(1,733 Views)
Hello!
I have some files compatible with Labview 4.0. Could you convert them to labview 8.6 compatible files? Thank you very much!
Message 69 of 81
(1,355 Views)
We have a dedicated thread for this: Upconvert Requests Thread
In the future please post your request there so it gets more visibility.
Message 70 of 81
(1,341 Views)
