Converting from Labview 7.1 to Labview 7.0
I am currently away from my computer with Labview 7.1
Can someone please help me convert all the labview files to Labview 7.0.
I have to make some changes to the program, but I only have Labview 7.0 on this computer.
Please help. I need ALL of the SUBVIS as well. Please....
THANKS IN ADVANCE
Krispiekream
Message 1 of 10
(5,603 Views)
I am unable to save your VI's for the previous version of LabVIEW because you have removed the block diagrams.  Please view the following article for more information on this.  Hope this helps, thanks!
Meghan M.
Message 2 of 10
(5,520 Views)
I got myself Labview 8.0 now, but I tried to save for previous. It doesn't allow me to save to 7.0.
I can only have to 7.1. Do you know why? i also replaced the files with no block diagrams with the files with. Can someone please help me? I need this badly.
Krispiekream
Message 3 of 10
(5,502 Views)
if you encounter subvis without the blockdiagram, please replace it with the one in the "New Folder"
thanks
Krispiekream
Message 4 of 10
(5,502 Views)
Hi krispiekream,
Can you attach the VIs without the block diagrams in 7.1 ? Some are in 8.0 & some are in 7.1. Smiley Surprised I m having only 7.1. Smiley Sad
Then only anybody can convert them to 7.0.
Because, LV allows downconversion upto only one earlier version, except 8.5, which allows for both 8.2 & 8.0. Smiley Happy
- Partha ( CLD until Oct 2027 🙂 )
Message 5 of 10
(5,477 Views)
Additionally, the last file you sent  (krispiekream.zip) appears to have many (most) of the files password protected
Putnam
Certified LabVIEW Developer
Senior Test Engineer North Shore Technology, Inc.
Currently using LV 2012-LabVIEW 2018, RT8.5
LabVIEW Champion
Message 6 of 10
(5,466 Views)
You don't need to know the password for a succesful downconversion, so that's not a serious problem. 😉
Message 7 of 10
(5,449 Views)
I was getting the password message at the "unzip" point and it seemed like a bunch. Just gave up after a while.
Christian, how are you doing with the fires. I seem to recall that you are over in Venice Beach, if so I guess you have a lot of city (no vegetation) between you and the fires.
Putnam
LabVIEW Champion
Message 8 of 10
(5,439 Views)
Yes, we're fine in terms of fires in Venice, however the air was and still is absolutely horrible. My eyes are still burning. I cannot image how bad the air pollution (smoke and particulates) was nearer to the burn areas.
Here's a recent satellite picture from NASA, look at the scale bar.
Message Edited by altenbach on 10-25-2007 02:29 PM
Message 9 of 10
(5,432 Views)
I tried to convert your subVI's back to LabVIEW 7.0, but at least two of them still have the block diagram removed.  Also, could you save the ones that are saved as LabVIEW 8.0 back to LabVIEW 7.1?  That simplify the process on our end, thanks!
Meghan M.
Message 10 of 10
(5,407 Views)
