Converting image to array, performing FFT of 2D array, and converting array back to image
How does it look if you autoscale z?
Can you run your VI so the intensity graph contains data, then right-click the intensity graph followed by (data operation...make current value default). Now place this intensity graph into a new VI, save, and attach it here.
Message 11 of 14
(1,354 Views)
Here is the VI containing the intensity graph.  I have also autoscaled Z.
Message 12 of 14
(1,351 Views)
Accepted by avaughn
Do some logarithmic mapping.
Message 13 of 14
(1,346 Views)
It works!  Thank you so much for your help!
Message 14 of 14
(1,334 Views)
