Converting instrument driver from v4.1 to v8.5 or v8.6
Would anyone be able to convert the attached driver library from version 4.1 to a version that could be read by version 8.5 or 8.6?  This is for a laser diode controller, and is the only version offered for download by the manufacturer (ILX Lightwave).
Thanks in advance for any help you can provide.
Richard
(3,382 Views)
Accepted by rorazi
Here it is as a 7.1 file.
(3,377 Views)
Thanks!
I  was able to open the vi's in v8.6.  Now I get to spend a little time to see if they actually work ...
Richard
(3,363 Views)
Would you be able to convert the driver library from version 4.1 to a 6 version, as you did for the 8 previously?  This is for the laser diode controller LDC-3724B, and is the only version offered for download by the manufacturer (ILX Lightwave).
Antony
(3,153 Views)
Why don't you just open the 4.1 version?
(3,134 Views)
