Converting string to number
Why the number doesn't contain the whole string and how to solve it ?
VI is attached
Message 1 of 17
(6,129 Views)
What are you actually trying to do? It looks fine to me, if your objective is to convert a string that only represents numbers in the Int32 range.
If your string contains more information that that you shoiuld look at Scan From String.
Message 2 of 17
(6,118 Views)
You need to explain in more detail.  What are you trying to put in the string control,  what are you getting, what are you expecting?
Message 3 of 17
(6,112 Views)
I am trying to take the "String" as it is without any changes and to be considered binary in  "number"
Message 4 of 17
(6,104 Views)
Message 5 of 17
(6,104 Views)
I don't understand the problem.  What doesn't work?  What data are you putting in?  You do know that this only returns an integer, don't you?
Message 6 of 17
(6,102 Views)
What do you have typed into the string?  That is the question.
Message 7 of 17
(6,095 Views)
binary bits
Message 8 of 17
(6,091 Views)
I want to scan the whole String ... how can I make this ? Because it scans part of the string not all of it
Message 9 of 17
(6,085 Views)
@MarinaNashaat wrote:
binary bits
What does that even mean?
Post a screenshot of your VI with the data typed in.  Or put the data in the control.  Right click and save the value as defaul.  Save the VI and attach that.
(Please put all of your information in one post.  No need to create another message.  You can even edit your previoius message within a reasonable period of time if you go to the options menu to the right of the message and choosed Edit Reply.
Message 10 of 17
(6,083 Views)
