PWM output and DIO output on same pin(MultiTasking)
Hi guys, ive encounter some problem in myrio 1900, which is using PIN31 for digital output and PWM output. while the testing , i cant sending PWM, i only can passing the read value from other Digital input and transfer towards PIN 31. ive tried to change in low level logic but myrio disconnect after 3-5 seconds. By the way ive attached few picture to clarify my current situation, hope can clarify my problem clearly.
thank you.
regards
vincent
Message 1 of 1
(2,923 Views)
