Converting strings to File Name
I have a vi that's creates a string that's a file name. This file name will be used to open the "Write LabVIEW Measurement File" Express vi. So, I would like to know how can I convert this string to File Name, 'cause I used the converter String to Path and the file was created but, when I tried to open it in the DIAdem, appears the follow error message: "Cannot load the file "xxxxxx.lvm" with the loading process "LVM". Error message for loading process: Cannot copy mass data from the "xxxxxx.lvm" file into the internal data."
Any help will be appreciated.
(3,671 Views)
If the file has been created and it's the name that you expect, then there is no problem with the string to path function. I would suggest opening the file with a text editor and see if it has the data you expect. Otherwise, there may be an issue with Diadem. There is a Diadem forum and you might have better luck posting there.
(3,653 Views)
