DSNewHandle fails with 2-D handle
All;
The following bit of code (StringRowAdd) mem-faults in a LV-called DLL, the other code (StringAdd) works fine. Can a programming god figure out what I'm doing wrong here?
...Dan
void StringRowAdd(TD4Hdl in_array, char *string[], int cols)
int i=0, j=0;
j = (*in_array)->dimSizes[0] * (*in_array)->dimSizes[1];
(*in_array)->dimSizes[0]++; if (j == 0)(*in_array)->dimSizes[1] = cols;
for (i=0; i
(*in_array)->String[j + i] = (LStrHandle)(DSNewHandle(sizeof(int32) + strlen(string[i])*sizeof(char)));
/* (*(*in_array)->String[j + i])->cnt=strlen(string[i]);
strcpy((*(*in_array)->String[j + i])->str, string[i]); */}
void StringAdd(TD2Hdl in_array, char *string)
int i, j;
j = (*in_array)->dimSize++;
(*in_array)->String[j] = (LStrHandle)(DSNewHandle(sizeof(int32) + strlen(string)*sizeof(char)));
(*(*in_array)->String[j])->cnt=strlen(string);
strcpy((*(*in_array)->String[j])->str, string);
typedef struct {
int32 dimSize;
LStrHandle String[1];
} TD2;
typedef TD2 **TD2Hdl;
typedef struct {
int32 dimSizes[2];
} TD4;
typedef TD4 **TD4Hdl;
(2,993 Views)
Hello dgholstein,
I could not see any glaring errors in the code snippet you posted. You may want to look closer at your for loop and confirm that you are not iterating out of your String array's bounds.
It may also be helpful to run your compilers debugger while calling the DLL in LabVIEW and watch the allocations in real time.
Good luck with the development.
Matt F
(2,824 Views)
