Converting text to an array (JSON) or passing in different datatype objects to a function
Using the JSONtext add-on with the sample text provided, I have quick success looping through each "methods" object, and displaying key value of each one. I plan on passing these arrays into .NET Framework methods later on.
I have two options:
1. How can I pass in a datatype to a function in labview.
2. Or, How can I convert a string "[ 2, 4, ..., 6]" for example into a LabVIEW array
(2,205 Views)
If you are not 100% sure how cluster or the read json looks like in advance, consider using something like here:https://pettaa123.github.io/labview-blog/2023/01/09/Set-Cluster-Elements-by-Ref-from-JSON.html
Actor Framework
(2,168 Views)
In JavaScript converting a JSON string to an actual array is extremely easy:
var stringArray = "[1,2,3]";
var actualArray = JSON.parse(stringArray);
console.log(actualArray); // Output: [1, 2, 3]
 Is there way to do it quick and easy like this in labVIEW?
(2,126 Views)
Accepted by topic author elibarber
Hi elibarber,
Use the malleable VI "Find Item (as LVtype).vim" to directly specify the data type:
For your use case, you can also use "Find Multiple Items (as LVtype).vim":
Raphaël.
(2,117 Views)
Note:  This VIM is part of the JSONtext Toolkit by JDP Science.  I use this library in almost all of my applications anymore.  It is an amazing toolkit.
(2,107 Views)
That worked! thank you!
(2,097 Views)
