Converting value decimal to celcius
Hi Everyone,
Hi everyone, I have a simulation to read the temperature of an object, I use a 3-wire RTD PT100 connected to an ADAM 6150. Actually I can read the decimal value, but I have difficulty converting the value into temperature.
(771 Views)
Hi farhan,
I guess there is a manual for your ADAM device. All you need to do is to apply the formula given in that manual to the decimal values you are reading...
(736 Views)
The RTD data sheet should give you the proper series resistor and scaling formula to convert the voltage drop across the RTD to temperature.
Without that you are kinda stuck. I guess you could use the formula for a similar RTD type and "calibrate" it by comparing the reading to a known temperature.
=== Engineer Ambiguously ===
(715 Views)
This statement is very ambiguous and can mean many things. The term "decimal" is a formatting convention to display numbers in decimal format (as opposed to e.g. hexadecimal, octal, or binary), while temperature is a physical property where the value is typically displayed in decimal, often with a fractional part and a unit. Can you see the confusion?
  1. A string (pink wire!) exclusively containing characters "0" ... "9" (and maybe "-", ".", or other allowed delimiters (or even  some leading and trailing other words and symbols).
  2. A numeric value (orange or blue wire!) where the indicator is formatted in decimal.
  3. Something else?
If it is a string, you need to scan it and convert to a numeric datatype before applying your scaling math.
Once you show us your code, we can probably identify the problem. What does the "decimal value" (sic) actually represent?
(675 Views)
@farhannmhd wrote:
Hi Everyone,
What do you mean by "simulation?"  What EXACTLY are your goals?
(665 Views)
If by value you mean a 4-20mA reading, then you just need to scale it with your measurement range. If it's -10 - 400°C it'll be ((Reading-4)/16 * 410)
Qestit Systems
Certified-LabVIEW-Developer
(623 Views)
