Coonecting lab view to max msp ?
Hi -
how can I get a stream of values out of labview and into maxmsp in realtime ?
(3,447 Views)
Nothing ? Is there anything that labview outputs to talk to other programs ?
(3,428 Views)
Accepted by topic author Gusss
UDP works.
(3,419 Views)
Thanks, I know how to import UDP into max  - how do I send the data out via udp from labview ?
(3,410 Views)
LabVIEW has many data communications protocols.  They're in this palette...  Data Communications > Protocols.  Go figure. Smiley Wink
EDIT: There are also built-in examples of how to use them:  Help > Find Examples... Networking.
LabVIEW Pro Dev & Measurement Studio Pro (VS Pro) 2019
(3,404 Views)
There are UDP primitives. I started with the example and played with the Bytes until they worked. This was an array of U16s:
(3,397 Views)
