How do I output (a voltage) to a daq from a boolean true.
 I am doing a voice recognition software program and when the program recognizes a specific word it activates a boolean indicator.
I need to output a signal preferably dc voltage to control a model car.
(4,380 Views)
Hi Kindred,
      Search this site for VISA, "serial port", and "parallel port".
I think the signals on a PCs serial port (if it has one) are 0 or 10V (+/-?), and the parallel port signals are around 0/3.8V.  My memory is terrible, so your results may vary,  but there is a significant difference.  Anyway, its trivial to set them - once you've done your homework. Smiley Wink
Maybe this will get you started!
Cheers.
Message Edited by Dynamik on 04-26-2006 01:01 AM
When they give imbeciles handicap-parking, I won't have so far to walk!
(4,373 Views)
If you need to output different voltage levels depending on what boolean goes high, a simple setup as shown below would do the trick.
The Search Array looks for a True value in the boolean array and outputs the index of that element. (if none are True, it outputs a -1) This then indexes out the corresponding value from the numeric array which can then be sent to your DAQ board.
Ed
Message Edited by Ed Dickens on 04-26-2006 07:48 AM
Ed Dickens - Certified LabVIEW Architect
Lockheed Martin Space
Using the Abort button to stop your VI is like using a tree to stop your car. It works, but there may be consequences.
(4,359 Views)
Could you please help me out? I am trying to use this Labview to power a LED on my NI ELVIS. Attached is my LABVIEW. I cannot get the ELVIS to power the LED no matter what I do. Basically I have a seires of TF booleans that I feed into a digital output in the hopes that each will power a different LED.
(4,025 Views)
Did you select a channel?  I know nothing about the ELVIS boards but I believe they should mimic a standard DAQmx device.  You have to tell the DAQ Assistant where to send the signal somehow.  Click Add Channel (the + sign) and pick a physical output if you haven't already done so.
LabVIEW Pro Dev & Measurement Studio Pro (VS Pro) 2019
(4,017 Views)
