Copy Excel Chart to Labview front Pannel
I posted an example in this thread where I used the the Excel Range.Selection event with a callback vi to copy in LabVIEW a selected range in Excel. The callback vi would have to be modified to accept a single cell selection but this should be relatively simple.
EDIT: I used the Worksheet.SelectionChange event.
Ben64
Message 11 of 16
(1,845 Views)
But he simply wants to copy data in Excel, and paste it in LabVIEW.
Message 12 of 16
(1,841 Views)
Is this in Edit mode or Run mode?
George Zou
Message 13 of 16
(1,822 Views)
run mode
Message 14 of 16
(1,811 Views)
Accepted by alii001
1. Create a custom popup menu for the table.
2. use event structure to catch the menu select event.
3. use clipboard function to import the csv string from clipboard.
4. convert the csv string to 2D array of strings and display it in the table.
George Zou
Message 15 of 16
(1,801 Views)
Thank you.
With your direction key words "CSV", I searched the forum again with words" CSV + clipboard ", and eventually  found what I want.
https://forums.ni.com/t5/Example-Programs/Clipboard-Copy-amp-Paste-from-Excel-CSV-to-2D-Double-Array...
I modified a little of that attached VI,and it can fullfil my needs.
Message 16 of 16
(1,779 Views)
