Copy Operation
Hai ,
   I have a problem to copy a particular array data in my VI. see if i choose a Start Val button and its corresponding side checkbox to choose one particular value at a time from current VI to Sub VI when i press the Copy button in this VI...Actually i have a problem that to identify the current index value which is checked....
(3,579 Views)
Hello LabView5,
you can take the slider position as an offset. Slider_position + check_box = index in array. Is this the right understanding of your problem?
Mike
(3,575 Views)
How can i measure the slider positions offset value
(3,570 Views)
Hi
the offset position should be the value from your chosen Slider.
Mike
(3,568 Views)
Mike actually i have coustamized the Array index Inc/Dec to Slide display. So now how to get the Slide Index value
(3,565 Views)
Hi
you can read the actual selected Index as a property of the Array. It is one under "index visible". It shows you the top left visible index. I can´t say you the english translation because i have to work with a german version.
I add an example for you.
Mike
Message Edited by MikeS81 on 01-17-2008 12:41 AM
(3,562 Views)
