Problems with Measurement and Automation Explorer (MAX)
Hello LabVIEWers,
I have been having a serious problem getting MAX to start and to remain stable. Here are the specifics:I am running LabVIEW 8.5 Full Development System on a Dell PC with 1GB of RAM and plenty of hard drive space. The OS is XP Pro and I also have McAfee Enterprise Virus Scan software.  MAX will start-up and appear to run for a few minutes and then the software bombs out. I get a "Measurement and Automation Explorer has encountered a problem and has to close" pop-up message. To fix the problem, I have uninstalled all NI software using MSI Blast. I have wiped the registry clean of NI keys as per instructions in previous posts. I have deleted any remaining NI software on teh hard drive including C:\program files\national instruments and C:\Documents and Settings\All Users\Application Data\National Instruments. I have then restarted the machine and did a complete fresh install from CD's, DVD's, and the harddrive (CD's written to hardrive and DVD written to harddrive first). I installed first the LabVIEW and then I installed the Device Drivers. I restarted the machine between installs. I have even installed the updated NIDAQ 8.6. After which I set protections on the NI directories to read/write. Ok, basically I have done all these things numerous times and I still cannot get things to work correctly.
I was able to get into MAX for a little while (it is somewhat stable immediately after a fresh reinstall). I defined 4 Simulated DAQmx devices and none of them acted like they were simulated. I received various errors saying that the device was not found or could not be started. So I basically could not run my software with the simulated devices. LabVIEW sometimes seems to work ok but just now, I got a "Error loading nidmm_32.dll, initialization routine failed" error. I also get the same error for nilvaiu.dll. Both of these DLLs are in the C:\Program Files\IVI\Bin and  c:\windows\system32 directories respectively and prior to the last time I started the software, all worked ok with LabVIEW.
Is my computer failing? Are there any other options to getting this installed without probems?
Please help.
Michael Froehlich
(3,188 Views)
Hi MF,
Did you try out uninstalling your Mc Afee antivirus suite also, & then reinstalling all the NI stuff?
Just a thought, may/may NOT work...Smiley Indifferent
- Partha ( CLD until Oct 2027 🙂 )
(3,179 Views)
Thanks for the suggestion Partha but since I am at a company, the sys admins don't like that sort of thing. I have tried like crazy to disable the anti-virus protection but cannot. I am going to try to get them to get me a new machine but I find it a little strange to have this happen only during the nimax software.
Michael
(3,173 Views)
