Copy file
Hi
In my Labview application, i copy a network file on the local hard drive where my application is located.
It works well but i don't know during copy where the progress is (i copy huge files about 100Mo).
So i would like to display a progress bar during copying like windows explorer does it for example.
Is it possible?
Thanks for your help
(4,213 Views)
You have to build such a thing yourself.
So you read one file and write another file, test with various blocksizes (at least in multiples of 512 bytes) for the best speed. But I don't think you get the same performance as the OS copy function.
Ton
My LabVIEW Ideas
(4,207 Views)
It not possible to it directly, but I found somethng that could help you in the right direction.
Quote from a VB forum:
"What I'd recommend is to do the copy "manually".
That is, open input and output files as Binary, and use Get/Put to transfer a nice large chunk at a time.
That way, you can do a progress display.
The larger the chunks, the faster the transfer"
You will have to get the file size before transfer to calculate the progress.
André
André (CLA, CLED)
(4,205 Views)
Hi
I'm gonna try this
(4,116 Views)
