Labview RT and PCI-7833R
can anybody tell me, if the NI PCI-7833R FPGA cards works in a desktop PC running Labview RT ETS? I heard, that it would not work and that you need a PXI realtime controller if you want to make Labview RT work with a FPGA card.
Matthias
(6,790 Views)
Far as I know, you should be able to run LabVIEW FPGA with any LabVIEW RT ETS OS target be it PXI or PC (given the right software version, e.g, 8.x). I see nothing to the contrary on the NI website either. Your local field engineer or salesman could tell you for sure.
(6,713 Views)
Hello Matthias,
yes the hardware support the ETS OS.
Look at the maual.
http://www.ni.com/pdf/products/us/2005-5528-301-101-D.pdf
Kind regards,
Elmar
(6,685 Views)
