Copy output to clipboard?
I was wondering if it were possible to place the output variable onto
the Windows clipboard. It seems like it would be possible. I know the
user can just highlight and Ctrl+C, but we're using a touch screen and
selecting text isn't as easy as it should be.
Thanks you.
Rick
rick@csciences.com
Chesapeake Sciences Corp.
1127B Benfield Blvd Millersville, MD 21108
Tel: (410) 923-1300 x3430 Fax: (410) 923-2669
Message 1 of 9
(19,820 Views)
Check out the ftp archives ftp://ftp.pica.army.mil/pub/labview there is a
vi for reading and writing to the clipboard. I have a copy on my computer
if you can't find it there, just email me at jeffbinslo@netzero.net
- Jeffrey Benton
Message 2 of 9
(19,820 Views)
use the attached VIs to copy text to/from the windows clipboard!
Message 3 of 9
(19,821 Views)
I found the same vi in more recent version of LV and i couln't use it. Thid one works fine. Thanks for that
Message 4 of 9
(19,625 Views)
There's also an Invoke Node method for the LabVIEW Application class called Clipboard >> Read from Clipboard and Clipboard >> Write to Clipboard. Both accomplish the same thing, are easier to use, and are platform independent! Hope this helps!
Message Edited by Jarrod S. on 07-24-2006 01:55 PM
Jarrod S.
Message 5 of 9
(19,613 Views)
Note that this is LabVIEW 8 only though.
Rolf Kalbermatter
Rolf Kalbermatter  My Blog
Message 6 of 9
(19,593 Views)
Unfortunately I'm always using LV 5.1 !! So clipboard.llb is better for me. Thanks for application class example and for forum
Message 7 of 9
(19,585 Views)
The Invoke Node is THE answer still in 2021 (thanks to Jarrod_S.)
Message 8 of 9
(7,835 Views)
The Invoke Node is THE answer still in 2025 (thanks)
Message 9 of 9
(533 Views)
