07-31-2023 06:51 AM
Hallo,
As part of my programme, i have to copy the graph obtained in the result into an already created Excel Template. The tricky part is that the image should fit inside the specified Rows and coloumns. I have 32 Rows and 9 Coloumns in which the image should fit. The copying of the image is working fine, but it is not being placed in this specified region. Can anyone help me regarding the same? The image is copied as bmp. Should i convert it into PNG and copy? will it make a difference?
07-31-2023 06:57 AM
Hi Indian,
Would it make more sense to fit those 32 rows and 9 columns to the size of the image?
07-31-2023 06:59 AM
Hi Gerd,
Thanks for the Reply. The problem is that, the template is an internal document from the company and i cannot change it.
07-31-2023 07:25 AM
07-31-2023 07:32 AM
umm Okay!
07-31-2023 07:46 AM
Your Subject is "Copying Image", but your image is of a graph created by Excel. In 2014, I posted an Excel Demo that showed how to create an Excel Worksheet with various columns, tables, and an Excel Graph (positioned wherever you tell it to go, and positioned and sized as you specify. The only "catch" is that you need to let the Report Generation Toolkit create the graph (but the demo shows this being done). You can find it at Revised "Generate Excel Report" Example .
See if this works for you.
07-31-2023 08:20 AM
Hi Bob,
I have written a programme in labview which creates a graph from Moment and angle values. This programme is being used for the past 3 years without a problem. Normally the graph is copied into the excel with the the help of Macros. Now the thing is that, inorder to minimize the use of this Macros, i want to add an extra button, with which the graph which is created in labview, will get first saved as .bmp file and then copied to the Specified cellls in Excel Template. This is the part with which i am having a problem. I am also not sure if it is possible to do so without Macros.
07-31-2023 09:04 AM
Hi Indian,
Recreate the VBA macro code by calling the corresponding ActiveX properties/methods…
07-31-2023 09:08 PM
Hello, Speedy.
In all your messages, you have (so far) not shown us any code, including how you create the data that you are trying to plot. Actually, I just tried to run my own Demo (which I've done numerous times this year because I mention it to others on the Forum, and usually end up trying to make sure it still works) and it blew up on me, saying that Excel wasn't installed. This is probably a bug caused by some weird update of my PC by The Powers That Be. I'll have to try it on my personal machine ...
Anyway, I need to see the LabVIEW code you are using to create the data that you want to display as an Excel Graph -- is there a reason you are hiding it from us? If you are using LabVIEW 2022 or 2023, please "Save for Previous Version" and specify LabVIEW 2019 or 2021.
08-03-2023 02:55 AM
Hey Bob,
Thank you for your Reply. I am using Labview version 2017. The programme is quite big and it is basically "Company Property". I dont know if i can post the full Labview code. I will clear with the Supervisor and let you know. I will attach a small part with which the graph is being copied to the Excel Template. This part is working, as the graph gets copied into the Template, but not at the corrrect cells. I tried changing the row and coloumn values, but no difference. I am also attaching the picture of the Template with the graph.
