Copying an LVOOP class
Hi, all,
How can I copy an LVOOP class, including VIs and controls?
Yes, I know I shouldn't... trust me, I need to. 🙂
- Steve.
Message Edited by SPM on 08-07-2008 04:13 PM
(4,328 Views)
Accepted by SPM
Use File>>Save As on the class library itself. Choose "Save a copy".
If you need to duplicate an entire hierarchy, create a Build Specification for "Source Distribution".
(4,305 Views)
Thanks -- that saves a ton of frustration!
- Steve.
(4,299 Views)
Thanks for your help,
I have some problems to  use Lvoo, could you help me?
How to edit the control or indicator of an object? or at least how to convert a class to a cluster?
(4,040 Views)
Create an XControl whose "Type.ctl" is the class control. Set its Facade.vi to be whatever display you want.
(4,030 Views)
