Core 1, exercise 3-1 question
I'm new to LabVIEW.  Doing the Core 1 course online.
Exercise 3-1 calls for an NI Instrument Simulator to simulate communication with an instrument over GPIB.
However, I don't have one of those.
Is there a way to complete the exercise without it?
(2,051 Views)
It only calls for a simulator if you don't have a real instrument. It specifies GPIB as it requires less setup than RS232 or other protocols as the setup is in the H/W.
Do you have access to any GPIB instruments (easiest) or RS232 instruments?
if not you can probably purchase a really simple RS232 thermometer from somewhere online for £20 or less.
like this:
TM: RS232 thermometer | Papouch.com
James
CLD; LabVIEW since 8.0, Currently have LabVIEW 2022 SP1 installed
(2,032 Views)
Thanks James.  We have some mass flow meters with RS232 connectors.
I'll try using one of those.
Mike
(2,009 Views)
