Correct usage of compactDaq
I have a new project which uses compactDAQ 9189 and AI modules 9205 and 9206.
How Do I use this Board?
From the short review I have made, It seems that the cDaq uses  NI DAQmx although it is a real time platform.
Am I correct?
Moreover, where can I find an example project for the cDaq 9881 using C series AI 9205 and 9206.
Thanks!
GIl,
(1,700 Views)
Accepted by gilmaor1
Hi gilmaor,
Am I correct?
For compactDAQ devices you use DAQmx.
And you are not correct: compactDAQ devices are not realtime platforms! (A compactRIO is a realtime platform!)
Are you using cDAQ9189 or cDAQ9881 - or both?
You will find all those DAQmx example VIs in the example finder. There are lots of examples on reading AI signals…
(1,675 Views)
Thanks for your reply.
Now I can continue the working.
I'm working with cDaq 9189
(1,631 Views)
