Corrupt Vi file, Labview 7 can the file be recovered
I was editing a front panel in labview 7 and I had an error message, then labview crashed.  Now
I can't read the file, even after a reboot.  Is there a way to recover this file or most of it ?
I was incrementing verison numbers, and saving my work every few minutes, but this file
had several hous of front panel work on it.  If I can recover it, I would only loose a few
minutes of work versus several hours.
Bob.
(2,771 Views)
Contact TechSupport. They may have decorruption tools for your VI.
(2,759 Views)
Hi rfmccoy,
Do you have anymore information about the error that happened, such as an error number or description?
Was it a standard windows crash error, blue screen of death or a LabVIEW error?  Also, what happens if you try to reopen the VI?
Rishi L
Applications Engineer
(2,739 Views)
