Could Someone send me a 'VISA Configure Serial Port.vi'???
I need that VI from LabVIEW version 6.1! My mail is ani@geola.com
Thank You.
(2,612 Views)
I made a vi that does the same and can serve for you as an example. look in the help how to use it.
part of it is 6.0 and part 6.1 but that is no problem.
The 6.0 vi's will be converted when loaded
greetings from the Netherlands
(2,612 Views)
You should have this VI in your Instrument->Serial I/O palette. Did something happen to it?
(2,612 Views)
