Could someone please provide feedback on if I have programmed timing with RTSI cable corectly?
Hi everyone,
I have been trying to get the AIs on Dev0 and Dev1 synched using the RTSI cable, which has been configured in MAX... Is the below code sufficient to synch the signals across both devices? Or do I still need a digital trigger?
I was using a digital trigger with a flat sequence etc as per the Labview example (hence the master and slave labels still remaining in the code), but I couldn't get Dev0:ao0 to write when "Waveform" was selected at the timing source for AO channel... I kept getting an error saying the refclocksoruce was already in use (or something to that effect)..
Any comments would be greatly appreciated.
Jack
Message 1 of 10
(4,883 Views)
Anything on a card that uses a sample clock must use the same sample clock.  So you need to set your AO to use the sample clock and clock rate as the AI tasks.
Edit:  Nevermind.  It's the reference clock that all of the card's tasks need  to be the same.
Message 2 of 10
(4,875 Views)
Ok... Thanks... Making more sense now..
But are the AIs on dev0 and dev1 using the same clock in my earlier code? Or do I need set the source clock on dev0 to "onboard clock" refclk on dev1 to rtsi0?
Jack
Message 3 of 10
(4,867 Views)
Hi jcannon,
Please refer to the example "Multi-Device Synch-Analog Input-Cont Acquisition.vi" from Help>>Find Examples>>Hardware Input and Output>>DAQmx>>Synchronization>>Multi-Device.  This offers a way to synchronize analog input on two X Series (PCIe) cards by sharing a reference clock and immediate start trigger from the master.  Alternatively, you can export the ai sample clock from the master as you have done and use the same trigger sharing mechanism as in the example.  For tighter synchronization, I would recommend using the latter method.  Good luck!
Brian G.
Message 4 of 10
(4,844 Views)
HI Brian,
Thanks for the feedback... I have tried doing what you suggested, but my selected timing source constants for the Dev3 and Dev4 are not compatiable and I am getting errors...I have tried a number of different combinations...? Not sure exactly what i am doing here?
Any chance you can take a look?
Jack
Message 5 of 10
(4,837 Views)
Hi Brian,
I did some more work on this... This works... Does this look ok?
Jack
Message 6 of 10
(4,822 Views)
Hi Jack,
The method used in the first attached VI should work without issue.  It would be helpful to know what errors you were receiving while using this code.  In the second screenshot you posted, there are many redundant Tasks being created.  You should only need one DAQmx Create Channel VI for each card.
I just remembered that since you are using X Series DAQ cards you can do channel expansion with your RTSI cable.  This allows you to combine the same type of Tasks from multiple cards into a single synchronized Task.
Synchronizing DSA, S Series, and X Series Devices With a Single NI-DAQmx Task
Brian G.
Message 7 of 10
(4,813 Views)
Hi Brian,
Thanks for getting back to me... I understand your point about redundancy... I made the expanded attachment for myself to help get my head around what I am doing... Without regard the redundancies, have I used the triggering correctly?
Also, I found this https://www.ni.com/en/support/documentation/supplemental/06/timing-and-synchronization-features-of-n... Figure 2 shows another example for synchronisation, but no trigger is used... Can you please explain the significance of the trigger?
Jack
Message 8 of 10
(4,804 Views)
Accepted by jcannon
Hi Jack,
Yes, the trigger routing you are doing is correct.  In fact, it corrects the problem with your first attached VI.  In that case the exported destination terminal (/Dev3/RTSI0) did not match the source terminal in the second task (/Dev4/RTSI0).  If you make these the same (i.e. /Dev4/RTSI0) you should get the desired result.
In regards to the synchronization examples you posted, without a start trigger the tasks will simply share a sample clock, but not a common starting point.  In most synchronization cases you will want to share both the sample clock and a common start trigger.
Brian G.
Message 9 of 10
(4,800 Views)
Thank you Brian...
Very much appreciated...
Kind regards,
Jack
Message 10 of 10
(4,797 Views)
